WD-45 box blade troubles
Donnie
08-21-2002 20:46:22
I just purchased a '57 WD-45 widefront with a 3 pt. 6' Rhino box blade. My trouble is when I lower the blade and the teeth dig into the ground, the back part of the blade lifts off of the ground due to the drawbar clevis moving side to side on the lift shaft. This also tends to kick the entire blade to one side or the other. Is there something that I'm missing, or something that I should try to fabricate to hold the clevis in the center of the lift shaft? Any help would be greatly appreciated. Thanks in advance.
Donnie
Eldon (WA)
08-22-2002 08:02:46
 Re: WD-45 box blade troubles in reply to Donnie, 08-21-2002 20:46:22
Do you have an anti-sway device on the lift arms such as chains? If the implement can move from side to side the top link will try to move with it. I saw an easy set-up where crossed chains were used (the rear of the arm on one side is connected to the front of the other arm). You could also try putting hose clamps on either side of the clevis (maybe a piece of rubber hose under them).
Craig
08-22-2002 08:33:52
 Re: Re: WD-45 box blade troubles in reply to Eldon (WA), 08-22-2002 08:02:46
I had the same trouble, I tried the chains and it was more trouble than the effort so I switched to using a set of big cable clamps on each side of the clevis cleared up the problem, as for lifting the rear of the box, youll probably want to add some weight to the back of it I used 4 100lb IH style front weights and had to reduce the number of teeth in the ground to four instead of seven
for traction purposes
