D14 Fluids?
DonP
08-20-2002 14:32:25
So....
The manual says 20 wt oil for the hydraulic system, the dealer says use the "same, quality hydraulic fluid everywhere (at least I think that's what he said...) and my brother says use PowerSteering fluid in the powersteering (which does make sense, sorta....)
-but who's right? Help?
steve
08-20-2002 16:17:14
 Re: D14 Fluids? in reply to DonP, 08-20-2002 14:32:25
DOn, everyone is kind of right. 40 years ago 20 wt engine oil was about as good as you could get. These days they make special oi for hydraulics and transmissions since they dont get too hot and cant boil off the condensation (water) like a motor can. These are trans-hydraulic fluids. You can get at farm store or WalMart. It is a 20 wt oil, but not motor oil. Steering fluid is about the same story. It has special additives to improve it over engine oil for special uses. Personally i would go with the trans-hydraulic fluid in the hydraulic and steering systems. To help confuse you , some people use transmission fluid (DEXTRON). Again, this is basically the same viscosity, but special additives which you probably dont really need.
