Re: WD generator loose wire
steve
08-15-2002 15:25:43
Douge, the F terminal is the ground wire, but it ran to the lights switch. it was grounded thru a resistor on the switch to give a "small charge" about 3 amps. when you pull out the light swithc the F terminal goes to full ground and gets about 10 amps charge. You can just connect the "F" to groudn on the frame if you want to test it for charge. for short runs of 30 minutes o.k. if you run several hours a day with tractor, you might want to get the new lights switch or add a resistor inline.
