D15 ll jumping out of gear
billy
08-14-2002 19:21:30
i was wondering what and how much trouble it would be to to fix tractor that is jumping out of 3rd and 4th gear? thanks for any help at all.
Gordon-(TN)
08-16-2002 23:57:10
 Re: d15 ll jumping out of gear in reply to billy, 08-14-2002 19:21:30
Billy there is a plate on the right side of the tractor just below the gearshift the bolts are countersunk with a slot in them if they are factory, put the shifter in nuteral take the bolts out remove the plate (it is above oil level)
look the gears over for damage, in most cases the
gears that are jumping out are worn off on the edges. some of the time you will find the shifting fork is worn enough that it isn't meshing the gears all the way. hope this helps
Gordon-(TN)
