D10 hydraulic lift
Hunter
08-13-2002 09:08:13
Looking at what i think is a D10. The lift cylinder ic under the right side of the seat. The control valve is there but no lines anywhere. Where do the lines come from going to the control valve. In other words where is the hydraulic pump? thanks
RMD
08-14-2002 07:40:46
 Re: D10 hydraulic lift in reply to Hunter, 08-13-2002 09:08:13
It depends. Early D-10 with traction booster had a hydraulic pump to the right of the PTO case like a CA. Early D-10 without traction booster had a hydraulic pump mounted on the engine. Later models with independent PTO (after mid-1961) had a gear type pump at the rear of the tractor.
