WD water and rust in gas
Charles
08-12-2002 14:16:12
How do you combat this in an old tractor?
JMS/MN
08-12-2002 22:55:41
 Re: WD water and rust in gas in reply to Charles, 08-12-2002 14:16:12
After removing and cleaning the tank, use a gas tank sealant to stop rust from flaking off.
ryan
08-12-2002 14:39:44
i have always had good luck with taking off the tank, draining it and put about 2 jugs of CLR (you can find it in the cleaning section of walmart) put the cap on the tank and shake it around for afew minutes then drain it out and put it back on the tractor (before you put it on the tractor run afew gallons of gas through the tank.)
