WD45 lift ram leak
Farmer Brown
08-12-2002 12:45:48
One of the lift rams is leaking on my WD 45, but it is not leaking at the seal. The leak appears to be between the base and middle sections of the body. My manual shows this as being all one piece. Is this a screw together joint? Assuming that it was, I tried tightening it but it wasn't loose. The joint between the middle and rod guide end of the cylinder is obviously a scree thread but this is not where it is leaking. What should I do ?
David T (MO)
08-12-2002 16:20:47
 Re: WD45 lift ram leak in reply to Farmer Brown , 08-12-2002 12:45:48
The base and middle section are threaded. There is probably a large o-ring inside that has rotted out causing the leak, or a crack has developed around/near the threads (from previous use of pipe wrenches). If the leak really bothers you, you can replace the o-ring. Breaking the cylinder apart isn't a big deal but you will need to be as gentle as you can (with those big pipe wrenches I mentioned earlier) so you don't crack the cylinder. Just place the wrenches as close together as possible.
Good luck!
Farmer Brown
08-13-2002 06:44:36
 Re: Re: WD45 lift ram leak in reply to David T (MO), 08-12-2002 16:20:47
Thanks for the response. It really help to know what you are working with.
