Another WD 45 Question
LH
08-12-2002 07:51:15
Hye guys I need to replace the leaking valve cover gasket on my Wd 45. It has a Wd engine and while I'm there I wondered if someone would please give me the specs and procedure for adjusting the valves while I have it opened up to make sure everything is set right. Thanks
Scott
03-11-2004 14:43:37
 Re: Another WD 45 Question in reply to LH, 08-12-2002 07:51:15
I was looking for some engine specs for a WD45 engine(gas G226)Cylinder head torgue mainly.Thanks for the help.
Duey (IA)
08-12-2002 10:15:24
LH (Joe),
Valve lash adjustment. Remember #1 & #4 piston go up & down together only on different strokes. Same for #2 & #3. With the valve cover off, turn it over with a hand crank until you observe the #4 rockers. The exhaust (last one)coming up and the intake starting down (top of the exhaust stroke). At this point, observe the position of your hand crank and check to see if the TDC mark is in the timing hole. When you do all of this on #4 and everything is in place, both rockers for #1 can be set as #1 is on the top of the compression stroke (TDC). Then follow the firing order 1243. When #1 is set, back up the hand crank to catch the notch and then turn the hand crank 1/2 turn stopping in the same place and the rockers on #2 are ready for adjustment. Then 1/2 turn for #4 etc.
This may sound complicated but it only takes 2 revolutions of the crank to complete the adjustments. Also by always backing up the crank a half turn to catch the notch and then stopping the crank in the same position each time, you are close enough to TDC to make the adjustments.
Years ago our bolck man told me to set valve lash at .020 for heavy duty use. Both intake and exhaust. Duey
LH
08-12-2002 11:42:43
 Re: Re: Another WD 45 Question in reply to Duey (IA), 08-12-2002 10:15:24
Thanks again Duey, but now you're gonna find out how dumb I realy am. Where is the timing hole located? I don't see anything on the fornt of the engine. I gotta get me a service manual to read up on all this stuff.
Duey (IA)
08-12-2002 19:47:08
 Re: Re: Re: Another WD 45 Question in reply to LH, 08-12-2002 11:42:43
LH, ("WD" &" WD45") The timing mark is found by looking under the flywheel housing for a small hole possibly covered by a small plate held with two wing bolts. The FIRE mark and the TDC mark are located on the flywheel through this hole. Use a little light colored paint to make seeing them much easier. Duey
LH
08-12-2002 20:26:46
 Re: Re: Re: Re: Another WD 45 Question in reply to Duey (IA), 08-12-2002 19:47:08
OK Duey thanks again.
