CA PTO seal
Mike
08-11-2002 19:36:54
I need to replace the PTO seal on my 52 CA. However, there is some kind of clutch gizmo on there I cannot get off. I found a set screw on one side and the grease zert on the other and removed both of them. I still cannot get it off.
Any ideas, anyone?
Thanks in advance
Mike
Harold Trammell
08-12-2002 13:01:05
 Re: CA PTO seal in reply to Mike, 08-11-2002 19:36:54
Mike make sure you put it back on, it could save your live. I need the PTO shaft for my ca 1952. I was not using my override and it broke my pto shaft. H.T. Where can I get a PTO shaft. [email protected]
Mike
08-12-2002 19:54:44
 Re: Re: CA PTO seal in reply to Harold Trammell, 08-12-2002 13:01:05
I live in NE Oklahoma, not many Allis parts in this area. No idea on parts. Thanks for the safety tip. I have realize this is a machine.
Mike
Rod (NH)
08-11-2002 19:48:01
Hi Mike,
It sounds like you have an overrunning coupler on your PTO shaft. Check to see if there is a spring pin that you can drive through from either side under the zerk fitting or the set screw. Mine has 2 zerk fittings that are 180 deg apart. I installed it years ago and cannot remember if there is a spring pin in there...I think there is.
Rod
Mike
08-11-2002 21:01:24
 Re: Re: CA PTO seal in reply to Rod (NH), 08-11-2002 19:48:01
I stuck a pin punch clear through the thing. I think it a slip clutch. It looks like a PTO exptension. If it is turned clockwise, it does not spin the PTO, or vixe versa.
Mike
Mike
08-11-2002 22:28:39
 Re: Re: Re: CA PTO seal in reply to Mike, 08-11-2002 21:01:24
Rod,You the man!!!!!
I went back to check and the end of the pin was about a 1/4" back into the hole where it was not visible until I really looked. I drove it out and
the gizmo just slid off.
What is its purpose? Is it just and extension?
The only implement I have now is a pull type brush hog.
Thanks again.
Mike
Rod (NH)
08-12-2002 06:30:36
 Re: Re: Re: Re: CA PTO seal in reply to Mike, 08-11-2002 22:28:39
Mike, it's NOT just an extension. It is called an overrunning coupler and it is a piece of safety equipment. Whenever a high-inertia piece of equipment is being driven by the PTO and the engine is rapidly throttled down, abnormally high stresses can be applied to the drive train because the high-inertia implement has a tendency to overdrive or backdrive the engine. In addition, depending on how the PTO is geared, the high-inertia implement can also tend to continue to drive the tractor forward AFTER the transmission clutch is depressed...not a good thing! An overrunning coupler acts as a one-way clutch to prevent either of these situations.
A brush hog is considered a high-inertia implement and you should always use that overrunning coupler, IMHO.
Glad you got it off...just make sure you put it back on before you use your brush hog.
Rod
Mike
08-12-2002 19:50:45
 Re: Re: Re: Re: Re: CA PTO seal in reply to Rod (NH), 08-12-2002 06:30:36
Thanks for all of the info. I have never had a tractor in my 56 years and am just learning about them. Really appreciate you and the help from this board. I priced the seal downtown and they told me it was $58. I said I think I saw it in a catalog for $5-7, so I am looking. $58????? ?
Thanks again
Mike
Rod (NH)
08-13-2002 18:49:09
 Re: Re: Re: Re: Re: Re: CA PTO seal in reply to Mike, 08-12-2002 19:50:45
Mike, $58 is outrageous! There must have been some misunderstanding. It certainly should be less than $10.
Rod
Harold in Tx.
08-13-2002 17:35:46
Go to a car bearing parts house and take old bearing seal with you... about 5.00----7.00
Harold in Tx.
08-13-2002 17:34:21
Go to a car bearing parts house and take old bearing with you... about 5.00----7.00
Mike
08-13-2002 23:35:12
 Re: Re: Re: Re: Re: Re: Re: CA PTO seal in reply to Harold in Tx., 08-13-2002 17:34:21
I have found good prices and several places to get them, thanks to all of you that have helped me.
Mike
