Compression Readings For WD 45
LH
08-11-2002 19:08:12
Decided today to check the compression readings on my WD 45, it seems to lack power under a load. It actually has a WD replacement engine in it, and the readings are as follows
#1 105 lbs
#2 115 lbs
#3 115 lbs
#4 115 lbs
Could someone please tell me if these are within the specs on a normal engine?
LH
08-11-2002 19:53:55
 Re: Re: Compression Readings For WD 45 in reply to norm , 08-11-2002 19:22:30
Thanks Norm I appreciate it. I know I've seen the specs in the archives before but I couldn't get them to work today.
