Why does my Allis Ca lose power under load?
Mike
08-11-2002 14:01:36
My Allis Ca loses power when put under load but otherwise runs fine. This make the tractor useless to me. Why is this happening?
mike
08-16-2002 05:35:29
 Re: why does my Allis Ca lose power under load? in reply to Mike , 08-11-2002 14:01:36
how much is this tractor worth? By the way, thanks to all for the info.
ryan
08-12-2002 14:42:48
i would figure on replacing the coil and see if that helps we had a m farmall that would run fine under no load but when we tried to do ANY THING it would strugle then die. We replaced the coil, plugs and cleaned out the carb and it ran better than ever.
steve
08-11-2002 14:18:32
probably fireing at top dead center. check governor weights for sticking. timing should advance with engine speed---i guess the carburetor is getting plenty gas?
Farmer Brown
08-12-2002 12:36:12
 Re: Re: why does my Allis Ca lose power under load? in reply to steve, 08-11-2002 14:18:32
We had a C like this once that was fixed by replacing the coil. It ran fine under no or light load but missed under heavy load. Evidently the spark was weak. Ran fine with new coil !
Allis lover
08-11-2002 15:07:18
Sale me the tractor I love CA Allis Chalmers Tractors. They are the coolest.I don't like allis chalmers but I love the CA's.
