Hand crank for 1953 B model
Jeff
08-11-2002 10:08:31
I have a 1953 model B,Allis-Chalmers and would like to know where i can order a hand crank for it?
Also,i've never hand started a tractor so are there any tricks i should know?
Thanks,Jeff
Jeff
08-14-2002 07:50:53
 Re: Hand crank for 1953 B model in reply to Jeff, 08-11-2002 10:08:31
Thanks,Gentlmen
I appreciate the information.
Diesel Don
08-11-2002 19:29:10
I don't know where you can find a crank,but I've had the opportunity to crank plenty of old iron.DO NOT wrap your thumb around the handle when you crank the engine.That way if the engine kicks back,the crank will pull out of your hand.Also,watch how you stand so if you get a kickback,you don't get hit by the crank.I got hit in the side of my knee by the crank on my buzz saw.I thought I broke my leg!The other thing to keep in mind is to be sure your engine is timed right.It won't eliminate kickback,but will cut down the chance of it happening to a minimum.I hope I didn't scare you too much.Cranking engines is safe if you are aware of what could happen.
