Re: HYDRAULIC MOTOR
Bob
08-10-2002 15:04:11
Use an Orbit motor that will run at a reasonable rate of speed off the hydraulics you have, and use a belt and pulley system to drive the chipper at the desired RPM, and it'll work just fine. Do you know the flow rate of the tractor hydraulics?
Hydraulic motors are rated a certain number of RPM'S per gallon per minute of hydraulic flow. If you do not know the flow rate of your system, a repairman with a flowmeter should be able to easily determine the flow rate for you.
