Allis c surging
peter
08-06-2002 18:01:14
new motor complete sent carb to zenith and they rebuilt it runs okay at low rpm but under load really surges need help dont now what to do new govenor is next but current one seems fine email me please [email protected] thanks peter
Duke(WNY)
08-09-2002 03:33:44
 Re: allis c surging in reply to peter, 08-06-2002 18:01:14
Here's a post I copied some time ago that you might want to check out:
Last week I was talking with the guy I bought the 1950 B from He asked if the Ventura was loose - why yes, it is. He then told me that if it's loose it will actually rotate around in the carb while the engine's running and do all sorts of weird things. The fix - take the carb apart, remove the gasket and set the two halves of the carb back together. If the body and top fit flush then the ventura is too loose. Make a *thin* washer and fit it around the Ventura so there's a small crack between the body and top of the carb when it's put together without the gasket. When I got home I checked and sure 'nuff, the carb body and top fit together flush without the gasket in place. So, I got a piece of 18 gauge aluminum electric fence wire, made a circle, and beat it flat with a hammer - probably 0.010 or maybe 0.015 inches thick (a guess on my part). I fit this washer around the Ventura just above the 4 flanges on the bottom so the washer would be between the Ventura flanges and the top part of the carb when the Ventura was installed. I put it back together and the difference was astonishing. Now it idles down to 1050 rpm with an occasional miss and I'm sure I can get it down further with a little adjustment (my 1950 will idle smoothly down to 750 rpm without a miss - it's sweet!). The tractor even runs better at load, and the governor works like it's supposed to (before when the governor cracked open it was liable to "flood out" immediately if I wasn't careful).
Leroy
08-08-2002 19:29:44
I've got a 45 C and a 46 C and they both have a surging tendency. The carbs aren't identical. I had an idling problem on the 45 and increased the intermediate jet size which seemed to increase (or started) the surge tendency on this tractor. I plan on reducing this jet size again, but haven't got around to it yet, maybe sometime this Fall. The idling problem was caused by someone installing the throttle plate upside down. I've had this tractor for about 2 years.
Tom Westerfield
08-07-2002 05:19:51
JMS/MN is on the right track. The B, C & CA uses the throttle rod spring too. Connects to a manifold bolt.
JMS/MN
08-06-2002 21:01:24
WD/WD45 uses a spring from the throttle rod to the block water draincock to control surging.
