Re: Clutch not disengaging
bcPA
08-05-2002 20:31:43
I would jack the tractors one rear wheel up off the ground, then block the other rear wheel so it wond roll of the jack. Next put it in gear before starting, then start it up with the clutch pedal pushed down. The one rear wheel will probably be turning even thou the clutch is in. while giving enough throtle so it wont stall apply the brake on the side up in the air. Carefully tap the brake a little at a time till it finally breaks the clutch loose. My super major loader had the same problem. wifes 86 year old aunt said with clutch in to run it into a bank of dirt to free up stuck clutch. It worked. good luck from bc.
