WD oil level
Peter
08-03-2002 12:46:17
I just finished draining out all the old oil from the transmission and the rear end. I have the shifter assembley off and the hand clutch cover open. I also removed the diff cover and cleaned it out. Today I started to refill it with oil but am not sure if I have enough in! My manual (Duetz Allis) calls for 17qts in the trans and 17 qts in the diff. Is this a combined figure? I assumed that all three reservoirs would come to level as they are all connected by ports. I have only put in a little over 20 quarts and the two visible areas have equalized but if its 17qts for each I am way short. Anyone know if the total is combined? I cant find a seperate fill plug for the diff. At $50 per pail I will return the second one if its not needed. the tractor is a 1950 WD. Thanks in advance Peter
Brian G. NY
08-04-2002 05:12:40
 Re: WD oil level in reply to Peter, 08-03-2002 12:46:17
17 Qts. (18 with PTO) total. Filling would normally be done using the 2 threaded plugs; one located in front of clutch lockout latch and one just to the rear of it.
Peter
08-06-2002 07:34:00
 Re: Re: WD oil level in reply to Brian G. NY , 08-04-2002 05:12:40
Thanks for the info, I had suspected that it was a combined figure. I had the covers off to have a "look see" as well as to make sure all was clean. Peter
