D-14 hydraulic pump
Shane
08-03-2002 04:55:17
I am having problems with hydraulics on my d-14. One day it worked fine the next day nothing. If you lift the lift arms up manually you can hear fluid going back to resevoir. The system seems a little milky so I changed the fluid and still no pressure at all. Is the pump bad? If it is where can I get an overhaul kit ?
