Since nobody asked (today), D14 firing order is ??
DonP
08-02-2002 18:57:10
I started my brother-in-law's D14 today for the first time in 6-ish years, and was surprised to find that it ran like crap!
(Ok, not too surprised. ) but it was dark outside by the tractor, so I figured I'd ask (in here where I can see) what is the firing order and is the rotation clockwise, or counter-clockwise?
Thanks for the help,
DonP
And since nobody answered, that wasn't the problem...
08-04-2002 05:33:54
 Re: Since nobody asked (today), D14 firing order is ?? in reply to DonP, 08-02-2002 18:57:10
A search of the archives brought up a list of nearly every other model of AC, all 1-2-4-3, and none of them CCW, so I guessed it to be a safe bet that the D14 was the same.
When daylight hit, I confirmed that none of the wires had "migrated", and found that the distributor was so far advanced that it was firing back through the carburetor. I backed it up nearly 15-degrees (or, "a lot", by the measuring device I had.) It purrs like a kitten now, and runs so smooth it won't even vibrate nuts and bolts off the gas tank!
-Now if I only knew where to look for the timing mark, I'd be able to tell if my timing-light agrees with my ear!
(I couldn't resist a ride around the yard. That "hi-nowhere-low" lever is a pretty nifty feature!)
Havin' fun,
DonP
steve
08-04-2002 17:27:07
 Re: Re: Since nobody asked (today), D14 firing order is ?? in reply to And since nobody answered, that wasn't the problem..., 08-04-2002 05:33:54
Don, i dont know nuthing about a D14, but my book says to remove the plug on the torque tube just behind the motor (i bet it looks at the flywheel, right?) it says the top dead center mark may be marked "center" on the flywheel. also has an advance mark "Fire". early models were 30 degrees, later units were 25 degrees. hope this helps.
Thanks, Steve
08-05-2002 06:04:54
 Re: Re: Re: Since nobody asked (today), D14 firing order is ?? in reply to steve, 08-04-2002 17:27:07
I got interrupted with an emergency trench-digging project at my brother's, so I'll check that out tonight. (I've gotta remember to buy a flashlight today, too.)
DonP
