LOW OIL PRESSURE ON MODEL C
JOHN CAMPBELL
08-02-2002 13:21:02
I HAVE REBUILT THE ENGINE ON MY MODEL C NEW CYL KITS,VALVE JOB,MAIN AND ROD BEARINGS,OIL PUMP VANES SPRINGS AND RELIEF SPRING STARTED THE OTHER NIGHT O/P COMES UP REAL SLOW AND WAS BARLY OFF 0 AT IDLE TRIED 2 OTHER GAUGES PULLED ENGINE AGAIN CHECKED VANES THEY ARE INSTALLED CORRECTLY IN PROCESS OF PLASTIGAUGING MAINS AND ROD AGAIN ALL ABOUT .002 FIRST TIME ANY HELP APP.THANKS JOHN
JOHN CAMPBELL
08-02-2002 18:27:56
 Re: LOW OIL PRESSURE ON MODEL C in reply to JOHN CAMPBELL, 08-02-2002 13:21:02
I DID NOT REPLACE THE CAM BEARINGS AND THE TUBE IS STIL IN THE OIL FILTER HOUSING THIS ENGINE WOULD HOLD 12 PSI O/P BEFORE O/H HOT 9PSI IS THE BEST IT HAS KNOW WIDE OPEN COLD VERY LITTLE AT IDLE TOOK A SHIM OUT OF EACH MAIN I WILL TRY TO GET IT TOGETHER TOMOROW MORNING TOO HOT TO WORK ON IT TONIGHT THANKS JOHN
Doug in OR
08-05-2002 15:43:07
 Re: Re: LOW OIL PRESSURE ON MODEL C in reply to JOHN CAMPBELL, 08-02-2002 18:27:56
I wouldn't experiment with shims in the main bearings. The same goes for your rod bearings. Get some plasti-gauge and shim the bearings for the proper clearance - probably around .002 - leave those alone once you get the proper clearance. Otherwise, check those items the others have recommended.
Harold
08-02-2002 14:26:06
What about Camshaft bearings?Did you replace them? They have alot to do with oil pressure.
Kip UT.
08-02-2002 15:08:53
 Re: Re: LOW OIL PRESSURE ON MODEL C in reply to Harold, 08-02-2002 14:26:06
Check & make sure that you did not inadvertantly throw the tube that goes up in the center of the oil filter away w/ old oil filter. If this tube is missing you will have VERY LOW oil pressure.
steve
08-02-2002 18:31:20
 Re: Re: Re: LOW OIL PRESSURE ON MODEL C in reply to Kip UT., 08-02-2002 15:08:53
at the front of the cam shaft in the timing gear, there is a spring loaded plug (in the middle of the cam shaft hole). make sure it got put back inside. oil is routed down this hole from back of the engine.
