WD Hydraulics
Dennis
08-01-2002 19:01:09
Does anyone know the gpm output and also the max psi that the standard WD hydraulic pump puts out? I wonder whether it can handle a full hydraulic loader or will I need an auxiliary pump!
DAve K
08-05-2002 09:08:37
 Re: WD Hydraulics in reply to Dennis, 08-01-2002 19:01:09
This is a high pressure low volume system. You will probably run out of volume if you have much movement on external rams. I have seen set-ups where folks have drilled and tapped the top of the fluid sump and mounted an additional tank on top to increase the volume of oil available.
Dave
punchie
08-02-2002 05:46:33
HI Dennis
Pressure is good for loading I was told it is around 3500 psi , I can lift a ton or more with My.
Speed is ok , for a backhoe I would say you would need a pump.
Punchie
