Clutch assembly for AC/ mod B-125 engine
Don E. Foster
08-01-2002 12:42:50
Need clutch assembly for power unit from AC, Mod 60 combine, same as on B tractor. Clutch is Rockford, Model RM 8 1/2 & 9"
Ted Seifert
08-05-2002 09:51:50
 Re: Clutch assembly for AC/ mod B-125 engine in reply to Don E. Foster, 08-01-2002 12:42:50
Sandy Lake Implement has them 724-376-2489. They will help you after the sale if you run into problems.
Al
08-01-2002 21:27:28
Clutch lining should still be avail through the dealer network and can easily replaced. I think a lot of tractor mechanics should have a riveting tool. If you have the smaller pressure plate you will need the smaller clutch plate assy. if more assistance is needed, I may be able to locate lining or assembly.
