head W/C W/D
Johnny N.C
07-31-2002 15:20:24
will a head off of a W/d fit a W/C 12 1/2'' studs 3 3/8 studs 1943 model if it will what else will I need to use from W/D.
Denny
08-02-2002 12:43:24
 Re: head W/C W/D in reply to Johnny N.C, 07-31-2002 15:20:24
It depends on the year of the WD. I've had two WD's. One had a single output water manifold on top of the head. The other used a two output water manifold. All WC's had a two outlet manifold. If your WD had the single outlet, you'll need the waterpump as well if you are using the head on a WC.
Johnny
08-04-2002 17:16:20
 Re: Re: head W/C W/D in reply to Denny, 08-02-2002 12:43:24
Thank's Denny the head in question is a W/D two long port's just like the w/c. I do won't to thank you for the info,,, Thank You Johnny..
