WD45 compression readings
Michael in Texa
07-30-2002 06:06:39
I'm in the process of buying a WD45 and figured I should check thed compression. Can anyone tell me what the readings should be on the tester?
Mark/Ks
07-30-2002 07:06:34
 Re: WD45 compression readings in reply to Michael in Texas, 07-30-2002 06:06:39
Somebody can correct me, But I believe it should be at or about 130 PSI.. My working WD-45 is running at 125 on three cylinders, and 120 on one.
After 12 years on a rebuild I guess that is still good.
Michael in Texas
07-30-2002 07:14:21
 Re: Re: WD45 compression readings in reply to Mark/Ks, 07-30-2002 07:06:34
Thanks. This will give me something to go by.
Brian G. NY
07-30-2002 07:30:59
 Re: Re: Re: WD45 compression readings in reply to Michael in Texas, 07-30-2002 07:14:21
The WD-45 manual is one of very few that states an actual compression pressure value; 125# @ 500 RPM. Most just indicate that there should be no more than 10% difference between the low and the high readings. Yours is mighty fine!
