Question for Brian G.. U-joint question..
Mark/Ks
07-30-2002 04:45:43
Brian, I went and got the NAPA 861 U-joint and it fits perfect.. You're right it cost 7.99.. Anyway my question is, I can only get two of the four snap rings back on. Were you able to get all four of your snap rings back on??? I'm sure I'll still be ok, I think I might just put a little dab of JB Weld on to secure the two without the snap rings... THANKS...
Brian G. NY
07-30-2002 07:36:28
 Re: Question for Brian G.. U-joint question.. in reply to Mark/Ks, 07-30-2002 04:45:43
All of the snap rings should fit back in. Check to see that you haven't made a mistake I once made years ago. I had let one of the needle bearings drop out of place and it wound up in the bottom of the cap which held the cap out just far enuf that the snap rings wouldn't go in. I beat the heck out of it 'til I figured what I had done wrong. Hope yours is as simple as that.
