Need parts!
Justin
07-29-2002 13:34:16
Hello I need the following parts if you have any please email me at [email protected] or if you have any information at all. I am new to restoring tractors. I am still in 4-H so I would really like to learn!
What I need:
A-C Model B:
Fenders
Battery Box
Gas tank cap
radiator
Grill
Steering wheel
Paint
Decals
Generator
Draw bar
lights
Wd, wd 45 or a wc? I am not positive as to which it is because it was built durign the war and so it has no serial #. Any help would be appreciatted !
Here is my list:
Fenders
PARTS tractor mostly!
Generator
Starter
Grill
Tool box
ENGINE
Lights
C and a CA
Fenders
Generator
Lights
Famrall Super A
lights
decals
steerign wheel
generator
Farmall C
? not sure yet.
As u can see I got a few different projects goign all run except the B and Wd! Tehre the only ones i have yet to get to run. I am trying to finish them all before christmas if possible for the x-mas parade! That would be somethign huh!
Thanks agaiN!
thank you! Justin
JMS/MN
07-29-2002 22:48:50
 Re: Need parts! in reply to Justin , 07-29-2002 13:34:16
WC has hand brakes, no hydraulics. WD has hydraulics, a straight shift lever and panel bolted on the right side of the engine. Late "53 WD has curved shift lever like WD45. WD45 has hydraulics,curved shift lever, solid cast engine- no panel on right side. Snap-Coupler hitch assembly. Head on 45 is taller than on WD.
Justin
07-30-2002 18:51:18
 Re: Re: Need parts! in reply to JMS/MN, 07-29-2002 22:48:50
Thanks for the response. It soudns like a WD then I will check in the morning for a side panel on the engine. It has hydraulics and a straight shifter. But a wc could have had hydraulics added at a later time right? What woudl the shifter look like on a wc? Because my tractor has both hand levers and foot pedals. To make it even more confusing!
Thanks,
Justin
