Company Logo (800) 853-2651 Shop Now
Re: Over-Running Clutch On D10
Gordon-(TN)
07-27-2002 22:05:09
Sounds like the over-running clutch is gone!
If the tractor has live p.t.o then you don't need it. one way to tell if you have live p.t.o is to put the p.t.o in gear with the clutch all the way down, trans in gear, let up on clutch slow, if the p.t.o starts turning & tractor don't start moving until the clutch comes up more, then you have live power. Hope this helps
Gordon-(TN)
Ridr
07-28-2002 07:22:25
 Re: Re: Over-Running Clutch On D10 in reply to Gordon-(TN), 07-27-2002 22:05:09
There is a shear pin that holds the overide on the PTO shaft , I would check that first . A new clutch only runs about 50 bucks
