Allis C mag
Mike
07-27-2002 08:51:39
I have a Mod. C that If I hook it up 12 volt I loose spark because the mag impulse quits .But If I try 6 volt my starter does not kick in. Should I rebuild the starter or Mag ? Or sell the thing ..... ..
steve
07-28-2002 17:41:23
 Re: Allis C mag in reply to Mike, 07-27-2002 08:51:39
Mike, the starter runs fine on 12 volts. How do you loose spark on a magneto, it has nothing to do with the battery? There are no battery wires connected on a mag. Do you have a distributor and coil??
Diesel Don
07-27-2002 19:48:36
Sounds like you converted to 12v.If you don't get the starter rewound it will probably spin too fast for the impulse coupling to do it's job.If you stay with 6v,there is a problem with the starter.If you mean the starter turns but won't crank the engine,it needs a new drive.If it won't run at all,the contacts may be bad in the switch.
