D-17 voltage regulator
mark
07-26-2002 14:39:07
I have a D-17 series 4 .I have been having trouble with the voltage regulator going out.I put a new one on and it works for awhile and the amp gauge just keeps jumping back and forth the hole time .Or am I hooking up the regulator up wrong?Could some one tell me if they is a way to test the generator to see if it is still good.
Also is the electrical system a + ground
steve
07-28-2002 17:58:00
 Re: D-17 voltage regulator in reply to mark, 07-26-2002 14:39:07
the D17 series 1v is a 12 volt positive ground system. your voltage regulator should have a "G" and "F" terminals that connect to the generator, and a "B" or battery terminal that goes to the ampmeter. After connecting the regulator you need to jumper the B and G terminals to get a spark which poloraizes the system and tells the regulaotr it is a positive ground. Other wise it might try to charge backward, or burn up. Do this with the engine off... After you see the little spark, then start engine and watch the ampmeter, should go alightly charge side. YOu can bypass the regulator by connecting the "A" terminal of the generator to the ampmeter (just connect the G and B wires off the regulator), and then ground the F wire from the generator. This will go full charge, 20 amps, and will not shut down when the motor is off, so dont leave it connect for more that a short 2-3 minute test. Ampmeter should read 20 amps when doing this test.---make sure the regulator is grounded good, a poor connection will also screw up the regulator.
mark
07-28-2002 18:10:59
 Re: Re: D-17 voltage regulator in reply to steve, 07-28-2002 17:58:00
thanks I will try this monday.
