WD specs
Author |
Peter
07-26-2002 07:50:21
Hi, I recently picked up a 1950 wd that although complete has sat out in the elements for some years. I cleaned out the fuel system but now I need to know the initial settings for the carb. It is a tsx 561, there is a needle on top and one in the bottom of the bowl. the other info I need is for the magneto. Are the wires installed clockwise 1,2,4,3?, my manual (duetz allis) doesnt say, on the gear that drives the rotor it looks like there is an A and a C, the manual says that to time the rotor there should be two marks, one for clockwise and one for counter clockwise. Are these the marks?, which do I use for my tractor? I know the mag works as I tested it and got spark (wire from coil to grounded plug). Last question is the mag supposed to snap as the engine is cranked? Thanks Peter
JMS/MN
07-27-2002 22:08:50
Re: WD specs in reply to Peter , 07-26-2002 07:50:21
Initial carb setting are generally 1 1/2- 2 turns out from bottoming out. At least should run, final settings are adjusted from there. Firing order is 1243, but initial starting point on the magneto is critical, generally #1 is top left or top right position as viewed from rear, according to when front cylinder is top dead center, ready to fire. Snap on rotation of the magneto is normal, and essential, as the impulse rotates.
Peter
07-29-2002 09:23:27
Re: Re: WD specs in reply to JMS/MN, 07-27-2002 22:08:50
Thanks for the settings JSM, I got it running and was driving it last night. I was going to far when setting #1 to tdc (allowing mag to click). set up just shy of tdc with rotor just ahead of mark and success! What oil is to be used in the transmission?, I know the quantity but not the grade. Thanks Peter
JMS/MN
07-29-2002 10:09:35
Re: Re: Re: WD specs in reply to Peter, 07-29-2002 09:23:27
Headed for work now but will get back to you- yars ago we used 140 gear lube- now maybe 80-140 multilube is ok.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
706 gas fuel tank&radiator
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
