1950 WD Hand Clutch
Tulsa TractorGu
07-25-2002 16:01:38
My brothers wd hand clutch is eather in or out very suddenly. Shouldn't it be gradual like a foot clutch? Is there an adjustment or will he need to replace th hand clutch? Thanks Much!!
Nathan
07-25-2002 20:28:09
 Re: 1950 WD Hand Clutch in reply to Tulsa TractorGuy, 07-25-2002 16:01:38
yeah... what them fellas said.
Duey (IA)
07-25-2002 19:59:55
Tulsa Tractor Guy,
The hand clutch can be very jerky if the oil level is too low and the clutch is dry or if the facing is gone from the clutch discs and it has steel on steel contact. On the left side just to the rear of the hydraulic oil fill, is the oil level and fill plug for the hand clutch. Check it out for sure. Inside the clutch there is a large pressure washer that provides the pressure that holds the clutch plates and discs together. The "snap" of the clutch is the over center linkage that transfers this pressure from the spring washer to the plates and discs. Duey
rayinny
07-25-2002 16:33:47
The WD I used would be gradual, you could ease into the work because the clutch runs in oil.
