Wd engine pressure,overhaul
justin
07-25-2002 10:19:39
how many p.s.i should the pistons have with a compression tester in a wd allis chalmers? if im gona overhaul the engine i want to put new rigns in and hone the cylinder and rebuild the valves and put new berrings in the bottom end of the conecting rod what else should also be done durin an engine overhaul thanks eveyone.
