AC 200 fluid
Ridr
07-25-2002 09:39:33
What transmission and engine (diesel) oils should I use ? it is used only for light discing and moving hay. Thanks for any help
ACORANGE
07-28-2002 06:53:49
 Re: AC 200 fluid in reply to Ridr, 07-25-2002 09:39:33
USE ANY GOOD 15-40 DIESEL ENGINE OIL AND JUST ABOUT ANY GOOD HY-TRAN OIL APPROVED FOR AGCO EQUIPMENT [LOOK ON THE LABEL] MY LOCAL OIL JOBBER SAYS MANY OF THE LOCAL AG DEALERSHIPS USE THE CHEAPEST HY-TRAN THAT THEY CAN BUY BUT A BETTER GRADE OF ENGINE OIL. YOU SHOULD BE ABLE TO FIND BOTH FROM YOUR LOCAL FARM AND FLEET, PARTS STORE OR LUBRICANT DEALER.
JMS/MN
07-25-2002 23:13:09
Buy the OPERATOR manual, and it will tell you which fluids to use, according to the ambient temperature.
Ridr
07-26-2002 05:02:48
 Re: Re: AC 200 fluid in reply to JMS/MN, 07-25-2002 23:13:09
I have already ordered it , but I need the tractor now
Please help !
07-26-2002 08:14:17
 Re: Re: Re: AC 200 fluid in reply to Ridr, 07-26-2002 05:02:48
what fluids types should I be running in a AC200 ?
DanD.
07-26-2002 17:59:27
 Re: Re: Re: Re: AC 200 fluid in reply to Please help !, 07-26-2002 08:14:17
Use 15W-40 diesel oil in the engine...any brand is fine, but I've always used the AGCO oil. For tranny, use trans-hydraulic oil, which AGCO sells as 821XL Power Lube.
Ridr
07-28-2002 07:18:21
 Re: Re: Re: Re: Re: AC 200 fluid in reply to DanD., 07-26-2002 17:59:27
Thanks Guys !! I really appreciate it!
