WD 45 Final Drive
LH
07-22-2002 21:47:51
Hello folks regarding my new WD 45 I still haven't conquered the brake pins but their soaking. Today while making a run in road gear I noticed a scraping noise in the final drives. When I pulled the fill plugs the only thing that came out was water. o I removed both final drive covers and they were full of water and very little else except ooolllldddd grease. Well I cleaned everything out real good, and noticed a few of the inside teeth on the lower gears are chipped at the edges. I plan on reflling everything with gear lube and also doing the tranny. Just wondered if anyone things those minor chips will cause any major problems down the road? Thanks.
Denny
07-24-2002 13:51:01
 Re: WD 45 Final Drive in reply to LH, 07-22-2002 21:47:51
I wouldn't be concerned unless there a lot of strange noises.
LH
07-24-2002 15:10:19
 Re: Re: WD 45 Final Drive in reply to Denny, 07-24-2002 13:51:01
Thanks
