WD45 hydraulic pump won't engage
Farmer Brown
07-22-2002 08:56:54
The hyrdraulic lever that turns the pump on seems to pulling against something that is stuck internally. The hand lever is down and only moves up far enough to take the slack out of the linkage. The tractor was my uncle's and I just recently acquired it. The hyrdraulics may not have been used for years. Anyone have any ideas on what is stuck or how to unstick it? I haven't tried forcing it. Is there a risk of breaking something if I do try forcing it?
Farmer Brown
07-23-2002 17:26:54
 Re: Re: WD45 hydraulic pump won't engage in reply to Jim Danforth, 07-22-2002 09:06:39
Thanks ! I took another look and you are right on. The lever that turns the pump on wiggles but the plate that rotates for the hold valve is stuck. The tractor was kept inside and faithfully pressure washed each fall , but apparently the washing and lack of use was too much for hydraulic control.
