Estimated cost of replacing a clutch in a d-17
John
07-21-2002 15:01:06
Hi everyone.
I have a 1958 d-17 that i would like to replace the clutch on. Has anyone ever had this done? I would like to here what it cost to have it done compared to doing it yourself.
I am getting ready to have the tractor painted. Infact alot of the sheet metal is already off and getting sandblasted and painted. I thought it would be a good idea to replace the clutch before i take the tractor itself over and have it painted.
Thanks
John
Denny
07-24-2002 14:12:44
 Re: Estimated cost of replacing a clutch in a d-17 in reply to John, 07-21-2002 15:01:06
John, I replaced one for a friend of a friend. Usually what wears out is the clutch disk while the flywheel and pressure plate are in good enough condition that they can be reused without machining. If you only need the clutch disk, rebuilt ones cost about $55. If the pressure plate is seriously grooved, a remanufactured one is about $85 (prices from CT Farm - others could be lower or higher). You can't really resurface a pressure plate because the dimensions will be wrong and will limit the life of a new clutch disk. If the flywheel is damaged, a good machine shop should be able to clean it up for $50. Throw out bearings are about $15 to $20 and pilot bearings are usually less than $10. Doing the job yourself could be as cheap as buying a clutch plate - $55. If you have someone do it for you, they will recommend a new pressure plate, pilot bearing and throughout bearing as well and some will want to machine or replace the flywheel. With labor it will probably cost $350 to $500 or even more. The guy I did it for paid me $100 and needed $80 in parts. The job took about 3 hours (two weeks elapsed time because he didn't have parts in advance). His professional installations estimates started at $500. I think we did this three years ago.
Good luck. Email if you want to ask other questions.
john
07-24-2002 15:11:19
 Re: Re: Estimated cost of replacing a clutch in a d-17 in reply to Denny, 07-24-2002 14:12:44
Hey thanks denny
Say I have not done this to a tractor before. Can you give me any pointers. Right now i am in the process of painting the tractor. I have already removed: hoods, radiator, front grill, gas tank. I think the only thing left to do is split the tractor right behind the engine.
What should i expect to see when i do this? Thanks
John
