Steering arm threads stipped
Terry
07-21-2002 10:13:30
I have a WD45, wide front end. One of the bolts that goes through the steering arm to the fork shaft is stripped. Actually, it may be the hole that the bolt goes into in the fork shaft that is stripped. I noticed in a diagram that the fork shaft has more holes than the two that are used to connect the steering arm to the fork shaft. Would these holes be threaded, and if so, could I remove the bolts and turn the steering wheel to line up two new holes? If not, what would be the easiest way to fix this? Thanks!
