Re: AC Crawler
Stan
07-20-2002 22:29:27
I have several model M's they are a good tractor I am surprised more of them arent out there.The best thing to do is get a manual. If the mag has been removed it is a little tricky to time, at least it was for me.Some of the m's were set up to run on the book calls it low grade fuel.If it is set up to run on low grade fuel you will see a letter K on the manifold just behind the stack elbow if the G is showing up it is set up for gas. This cover is reversable if the nuts can be removed. If one is set up for low grade fuel I am not sure if is is ok to run on gas. All mine are gas or propane. The firing order is 1243 1 being to radiator.No. no. 1 0n mag from rear is at 10 o'clock 2 is at 2o'clock no4 is at 5, and 3 is at 8 hope this helps, Stan
