Stuck WD-45
John
07-20-2002 05:10:10
Went to bushhog the other day and ran into some problems. Engaged the pto and let out the foot clutch and got nothing. Engine loads like it is turning pto but it is not. Shear pin is okay. Pto lever will not disengage. When I tried to move the tractor, engaged the hand clutch and tractor won't move. Any ideas? Can anyone recommend a good brand of repair manual that is easy to follow? Thanks.
Brian G. NY
07-22-2002 10:57:24
 Re: stuck WD-45 in reply to John, 07-20-2002 05:10:10
If it's not the bush hog that is "jammed", I would drain the oil at the PTO, pull the PTO housing down and look for something stuck in the gears. Something (I never could identify what) dropped down into the PTO unit on my WD while I was bushhogging. It got caught between the gears, broke a tooth off the PTO gear and "split" the PTO housing. A used PTO unit goes for around $150 in this area, so if you can avoid that expense you'll be doing yourself a favor.
Bill Hires
07-21-2002 09:48:05
Allis-Chalmers Shop Servuice manual AC-11, gives the best information for doing this. INTERTEC Publishing, PO Box 12901, Overland Park, KS 66282-2901 www.itsshopmanuals.com
