What Model?
Kim
07-19-2002 20:53:44
Folks
I have an AC tractor that I am trying to locate parts for.
Can any one tell me if the numbers 270 stamped on the top of the raditor housing is the model numbel number to be used when chasing parts?
If not do any of the following which appear on the left hand side (as you facr forward from the seat) identify the model 18034 (stamped into the body) da 15234 (cast not stamped) AEH 89 -142 also cast 2076? (also cast) the question mark is because the last digit is not legible and 2920 also cast.
Any help or suggestions will be appreciated.
Thanks
Kim
steve
07-20-2002 07:35:13
 Re: What Model? in reply to Kim , 07-19-2002 20:53:44
Kim, i am far from an expert, but none of those numbers mean much. Lets start out and get some basic information. What size are the rear tires? What size are the front tires. How big is the tractor? Is the top of the hood 4 ft above the ground or 7 ft? Does it have a diesel engine? Does it have 4 cylinders? Are the hood and radiator wraparound boxy and square corners, or rounded? How old do you think it is 1980, 1960, 1940? Does it have a c-channel frame around the engine and radiator, a plate frame, or no frame? this will give us a better starting point to tell you where the serial number is located, it changed every few years.
