Re: Brake Question on WD45
Duey (IA)
07-18-2002 15:10:05
LH,
That sucker sticks in the housing on both sides of the housing. Soak it a lot with penetrating fluid of your favorite kind and with a good vice grips, you may get it to come loose. They are all different. Some require a lot of heat, some just a few taps with a hammer to break loose the rust. Most stick tighter on the outside because of the exposer to the elements. Just be patient. Time and penetrating fluid will loosen it. Duey
LH
07-18-2002 15:56:05
 Re: Re: Brake Question on WD45 in reply to Duey (IA), 07-18-2002 15:10:05
Thank Duey, I'll keep soaking and hope it eventually breaks loose.
h.b. hUTCHENS
07-18-2002 15:55:03
Try using an air chisel (DULL) on the pin through the opeening in the botten of the housing while someone pulls on the pin. The vibration of thechisel seems to help breake them loose. H.B.
