Allis WC
WD and Spoked Wheels
Luke Peterson
07-18-2002 11:24:17
Does anyone know what year they switched from the spoked rear wheels to the cast iron type? Are the spoked rear wheels and cast iron type interchangable and did the spoked wheels ever come on the WD (or will they fit)?
JMS/MN
07-19-2002 23:08:02
 Re: Allis WC - WD and Spoked Wheels in reply to Luke Peterson, 07-18-2002 11:24:17
WC are 5-bolt wheels, WD are 6-bolt wheels. They do not interchange. All WD wheels are power-adjustable, not like the WC. WC came in spoke and solid wheel, 24 inch and 28 inch.
Noly
07-18-2002 18:50:09
my service manual states that at serial number 81757 (1939) they changed from 11.25 x24 rubber to 11 x 28 inch rubber. Not sure if they will iinterchange with a WD, it won't hurt to try if you have them available
Luke
07-18-2002 19:11:30
 Re: Re: Allis WC - WD and Spoked Wheels in reply to Noly, 07-18-2002 18:50:09
Thanks. I have seen several late 30's WC with the cast iron wheels, so I guess they are interchangable on the WC.
Kip UT.
07-19-2002 09:55:16
 Re: Re: Re: Allis WC - WD and Spoked Wheels in reply to Luke, 07-18-2002 19:11:30
Early un-styled "Hi-Crop" Wc's used cast center 36" wheels just the same as later styled "Hi-Crops. This was first use of cast wheel centers w/ detachable rims on a WC. Pressed steel 24",24' spokers,& cast center 28s will all interchange.
