HYDRAULIC SPECS
BRUCE
07-18-2002 08:20:06
I have a WD 45.... don't know what year.... would like to know the volume and pressure of the hydraulic system.... I was told it has a 4 piston hyd. pump..... Thanks, Bruce
Dave Grubb
07-19-2002 13:36:04
 Re: HYDRAULIC SPECS in reply to BRUCE, 07-18-2002 08:20:06
The system pressure is in the area of 3200-3500 psi. I can't recall the output but it is small compared to the lower pressure sytems. DON'T use low pressure system components with this system unless you use a pressure reducing setup.
JMS/MN
07-18-2002 09:58:48
The pump is a four-piston pump, runs 2200? lbs, relatively low volume- 6-9? gals per minute? Check the serial number located on the read side of the differential, left side, compare it to the serial number listing on the left side of this page for the year of manufacture.
