AC WD45 Engine Block w/o Numbers
haig stephens
07-15-2002 14:37:58
I just purchased a WD45. The Serial Numbers (WD187572) on the rear axle indicate that it is a 1954. However, under the intake manifold, the stamping surface on the engine block does not have any numbers stamped on it. Does anybody have an explanation for this? Does the number set "NM7S" (which is not stamped but cast as part of the block) just above the stamping surface, to the right mean anything? It does have the curved shifter.
Also, anyone have a wide front for sale?
Look forward to and appreciate any info.
Haig
Muscatine, Iowa
DanD.
07-15-2002 17:54:11
 Re: AC WD45 Engine Block w/o Numbers in reply to haig stephens, 07-15-2002 14:37:58
Could have been a replacement block. I don't imagine a replacement block would have come with any serial numbers stamped in it.
Brian G. NY
07-17-2002 17:42:36
 Re: Re: AC WD45 Engine Block w/o Numbers in reply to DanD., 07-15-2002 17:54:11
I have a '56 WD-45 with a "no number" block, too. I assume like you say, it is a replacement block.
