Wheelie Bars for tractor
Travis
07-14-2002 12:15:12
Recently I noticed a picture in your classifieds which showed a B or C Allis with what appeared to be dragster type wheelie bars on the rear end. I am going to use my tractor to pull up manzanita bushes and I would like to see if these bars would be suitable to stop the front end from coming off the ground dangerously high. Also, what front end weights are available and what do they attach to? Any info would be helpful. Thanks, Travis
puller4life
07-14-2002 21:16:42
 Re: Wheelie Bars for tractor in reply to Travis, 07-14-2002 12:15:12
Could you find it and show it to us? I would like to see it if you can find the picture.
The wheelie bars show hold it. AS lite as a B,C,CA is it don't take must to hold it down.
Weights make you bracket that bolts in the 2 bolts on each side that goes in the flywheel.The two bolts are were you break the tractor apart between the torque tube and engine. then make it come across the front and bolt in the two bolts in the very front. Make your weights out of a pieace of flat steel and put a handle on them.
