Re: WD Gear shift problem
Farmer Brown
07-12-2002 08:36:58
Also check for excess play up and down at the middle ball with the groove. This contributes to it's freedom to come up out of the forks, same as the ball at the bottom end being worn. Cure is to replace cup shaped hold down washer/bushing or find a shim washer of suitable size to add in on top of it under the snap ring.
