Clutch pedal is loose
John
07-11-2002 17:08:45
Has anyone had any problems with the clutch pedal being loose on the shaft it turns on? If so did you fix it? How?
Thanks
John
Tom
07-11-2002 17:59:40
 Re: Clutch pedal is loose in reply to John, 07-11-2002 17:08:45
If it is a B or C type tractor watch out it doesn't get too loose. It can go past the stop and swing around and down engaging the clutch again and you will get quite a surprise when it does!
Craig MO
07-11-2002 17:58:35
Take the pedal and have it bored out and a bushing put in. Pull the shaft out and have it built up and turned down and it will be like new.
john
07-11-2002 20:06:58
 Re: Re: Clutch pedal is loose in reply to Craig MO, 07-11-2002 17:58:35
The tractor is a d17. That shaft you are talking about, it doesn't go through into the transmission does it? What would you use to pull the shaft?
thanks
david l wilson
07-15-2002 21:54:25
 Re: Re: Re: Clutch pedal is loose in reply to john, 07-11-2002 20:06:58
the shaft you are talking about does go into the hand clutch housing,i had a heck of a time getting mine out ,used pipe wrench,vice gripps and a hammer, but i finally got it . i bought a new one from agco for about $ 30.00 .be careful if you do this as the detent ball for the pto shifter is on the inside of this shaft and will fall into the bottem of housing when you pull the shaft.then you get to split tractor to fix the screw up [ expiriance talking] but not too bad a job. i had my pedal bored and a bushing installed, works great now. good luck. david l wilson [email protected]
