Re: '39 Model B won't start
steve
07-11-2002 15:13:59
Jake, you know it needs gas, spark, compression and correct timing on all three to run. You got gas, you gat spark, is the timing right? Why did it backfire? I would crank the engine slowly while someone looks thru the 1 inch hole or left side looking at the fly wheel. When it gets just before the TDC mark, see if the mag is pointing to no 1 (on compression stroke), or just pull the no 1 plug, ground it to the engine and see that it "sparks" as you go to TDC. I assume the backfire might be due to timing, governor slip, etc, and not a valve-compression problem.
