Re: WD Gear shift problem
John (C-IL)
07-10-2002 18:44:47
That is a common problem when those transmissions get a little worn. Take the shifter out of the tower and use a long screwdriver to put the tractor in neutral, then drop the shifter back into the forks and you're in business. It takes about 2 minutes after you have done it a time or two. John
