Flushing the coolant system?
John
07-10-2002 07:26:30
I am in the process of restoring a D17. I had the radiator cleaned inside and out. Before i put it all back together i would like to flush out the engine block. Has anyone done this before? If so would you give me some pointers on how to do this.
thank
John
Mike
07-10-2002 20:34:14
 Re: Flushing the coolant system? in reply to John, 07-10-2002 07:26:30
I flushed out my CA just using auto radiator flush. To rinse it out I ran the water in and opened the drains on block and radiator. Keep radiator and block full of water. Rinse for about an hour with motor and water running. Then turned off motor and drained it dry. I then used SW sealer in radiator and block to seal up leaking head gaskets, etc. Again following can instructios. Added anti-freeze.
Mike
