D-19 wide front end swap
John
07-08-2002 20:13:46
I found a d-19 with a wide front end sitting in the weeds. I would like to put that wide front end onto a d17. Will the swap work?
THanks
John
JMS/MN
07-08-2002 22:15:17
 Re: d-19 wide front end swap in reply to John, 07-08-2002 20:13:46
Call a dealer and check out part numbers- if they are the same, it should work, but I would expect a heavier front end on the D-19.
david l wilson
07-15-2002 22:04:48
 Re: Re: d-19 wide front end swap in reply to JMS/MN, 07-08-2002 22:15:17
it probably will not work the d19 is longer due to the 6cyl. engine. the d19 is heavyer.is also 6 bolt wheels.good luck david l wilson i2bzy@hotmail.com ps: i would do alot of mesuring before i tried it ,if you need me to i can check my 17 & 19 fronts to see , just let me know
